Dean007
Recognised Expert
Message 11 of 12
Re: Poor BT mobile signal at home
LG G4 does support Wi-fi calling from EE.
To be honest it shouldn’t be too much longer, also 4G calling may help with coverage too!
Danwilliams
Message 12 of 12
Have you tried switch between 2g/3g/4g when not using data. I work for virgin Mobile and if our customers have genuine low coverage we would consider ending the contract. So I don’t know if that’s something you might be thinking about. Also make sure all your software is up to date on your mobile.
