Message 1 of 2
Poor Mobile Signal
Hello,
  I have very poor BT Mobile Signal, work phone is Vodaphone / wifes mobile is EE - both excellent signal.)I have 2g using Galaxy J3, excellent internet (from BT)
Any ideas ?
1 REPLY 1
Recognised Expert
Message 2 of 2
Re: Poor Mobile Signal
Hi @SlimJimBaxter
I would expect you to get the same sort of coverage as the EE handset. Do you have the same issues indoor out and in different locations? Can you check the following settings..
Enable or Disable the 4G Connection
  1. From the home screen, tap Apps.
  2. Tap Settings.
  3. Tap Mobile networks.
  4. Tap Network mode.
  5. Tap the preferred network mode: To connect with 4G when available, tap LTE/3G/2G (auto connect). To connect only with 3G and 2G, tap 3G/2G (auto connect). To connect only with 3G, tap 3G only. To connect only with 2G, tap 2G only.
If the issue persist it maybe worth trying a replacement SIM.
