Ben57
Message 1 of 3
Poor mobile signal
Hi
I live in the Sg8 area and have always had a poor mobile signal, never seem to get more than one bar on my phone, any help would be appreciated
2 REPLIES 2
ctrlz
Message 2 of 3
Re: Poor mobile signal
Try changing network mode on your handset, you might be able to get stronger reception on 3g/2g.
If its mainly at home use wifi calling if your phone supports it, then you aren't relying on mobile signal at all, just the wifi connection.
DavidM
Moderator
Moderator
Message 3 of 3
Hi @Ben57 and welcome back.
Sorry you're not getting a great mobile reception. Your best bet might be to follow @ctrlz advice. Can you give that a try and let us know if it helps?
Cheers
David
