Paulbriant
Message 1 of 2
Porting number
Not sure if I've got the PAC code process online right? How long does it usually take?
Tags (1)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Porting number
Hi Paulbriant,
It usually takes one working day. If you take a look at Can I keep my number when I move to BT Mobile? you'll find a few more details about how to move your number across to BT.
PaddyB
