oakserver
Message 1 of 7
Problem turning off BT Mobile parental control
Hello,
Signed up to BT mobile about a week ago. My mobile account appears to have parental controls enabled and I can't turn them off. The message says I have to wait 30 minutes before changing the settings.
I've been waiting a few days now, something seems to be up.
Below is the message:
"Your settings are not available right now
Thanks for changing your parental control settings. You'll have to wait up to 30 minutes before you can change them again.'
6 REPLIES 6
NeilO
Moderator
Moderator
Message 2 of 7
Re: Problem turning off BT Mobile parental control
Hi @oakserver thanks for posting, are you getting that message when you're trying to manage the BT mobile parental controls on this link?  www.bt.com/mymobile >
oakserver
Message 3 of 7
Hi - Yes, that’s the one. Just checked still says :
“Your settings are not available right now
Thanks for changing your parental control settings. You'll have to wait up to 30 minutes before you can change them again.”
Oddly I cannot see details of my mobile or the status of Wi-fi calling etc either. Don’t know if that has any thing relating to the problem?
NeilO
Moderator
Moderator
Message 4 of 7
Hi @oakserver I'll send you a private message so you can get in touch with the moderation team. We're quite busy at the moment so it will take us longer than we would like to reply so if this is urgent you may be best raising a fault via the Mobile helpdesk
AshleyHay
Message 5 of 7
Hi,
I am having a similar issue managing parental controls and spend. Please can you advise how I resolve this.
PaddyB
Moderator
Moderator
Message 6 of 7
Hi @AshleyHay,
Thank you for posting. I'm sorry you're having problems managing the parental controls on your BT Mobile. The best way to get this fixed is by calling the BT Mobile team on 0800 800 150.
Paddy
AshleyHay
Message 7 of 7
Thanks Paddy
