You can try cleaning the SIM a dry cloth and then you can try switching on the device again.
If it is still not working, then it might be locked to another network where you have used it earlier. You'll need to get it unlocked by the mobile provider you originally bought it from.
if this also does not help, try buying the replacement sim.
