Message 1 of 6
Re: Cant change parental controls and spend management for 1 of my 3 family SIMS
I have the same prob i have personalised my number and still i can't change parental control on1 of the 3 bt sims i have help plz
5 REPLIES 5
Message 2 of 6
Hi @Biggie91, welcome to the forum, and thanks for posting. I've moved your post to create your own thread as the previous thread is already solved.
I'm sorry that you're not able to manage the parental controls for one of your sims. I take it you are able to manage it ok on the other sims? Also what happens when you try to manage the controls ie do you get an error or does the screen not move on?
Cheers
John
Message 3 of 6
 just keeps popping up with that message can't do anything and yes my other numbers i can change anything i want
Message 4 of 6
Hi @Biggie91, thanks for that info and the screenshot.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you with this.
Cheers
John
Message 5 of 6
@Biggie91 @JohnC2
Doesn't that screenshot contain private information - just what the scammers need!
@Biggie91  Now that @JohnC2 is on to the case, I suggest you edit your post and remove that screenshot or at least hide the personal information.
Message 6 of 6
Hi @Carlusha, thanks for highlighting that and I've removed it now 🙂
Cheers
John
