Moderator
Moderator
Message 11 of 16
Re: Merging two BT accounts
Hi @paul_stephens,
I've checked the two accounts and I can see that they've been merged together. Your BT Mobile account has been closed in favour of your main account Smiley Happy
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
paul_stephens
Message 12 of 16
@DanielS thank you for all your help 🙂
paul_stephens
Message 13 of 16
@DanielS do you think the closed BT Mobile account could be removed from My BT? I've seen in other threads this is possible. Many thanks.
Moderator
Moderator
Message 14 of 16
Hi @paul_stephens,
I've removed that for you now Smiley Very Happy
Is there anything else that I can help you with or are you happy?
DanielS
Kudos”
paul_stephens
Message 15 of 16
That's all. And I'm very happy. Thank you 😀
Moderator
Moderator
Message 16 of 16
That's brilliant to hear Smiley Very Happy
Take care and have a brilliant weekend
DanielS
Kudos”
