Message 1 of 4
Re: Mobile Porting Problems sorted
I persuaded my wife to transfer to BT Mobile we gave BT a PAC code on the 28th December.
Got confirmation that number would transfer on the 2nd January - it didn't.
Contacted BT on the 3rd - network problems - would happen later that day - it didn't.
Contacted BT on the 4th - network problems - Give it 24 hours but would probably be done by end of that day - it wasn't.
Contacted BT on the 5th - terribly sorry - have £10 credit to your account - will be done by the end of the day - it wasn't.
I an a BT fan but this is getting silly!
How do I get the number transfered and achieve a cesation of hostilities???
Only good thing it appears we are definitely not alone.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Hi @Wobert
I can have this looked at for you. Send me over an email with the details. You'll find the contact the mods link in my profile.
Stuart
Message 3 of 4
Sorted now - thank you very much.
Peace restored!
Moderator
Moderator
Message 4 of 4
Hi @Wobert,
Thanks for letting us know this is sorted. I moved your posts so we can close things off. I can see @RobbieMac has been dealing with this so I'll let him know you've posted.
Cheers
David
