Wobbly
Message 1 of 11
Re: Parental control
Good morning. I am running the latest version of android on a HTC M9
I joined BT two weeks ago and yesterday tried to turn off parental controls.
I am being told they are off but i am still getting page blocking.
Any idea?
10 REPLIES 10
Message 2 of 11
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
Are you connected to mobile data, or your home BT Broadband?
Wobbly
Message 3 of 11
Morning Keith. Mobile data
Message 4 of 11
If you have altered the setting on your mobile Parental Controls (not your broadband parental controls), then you would normally have to restart your phone to clear any cached DNS settings.
Wobbly
Message 5 of 11
Hi Keith. I have just restarted and still getting blocked
Message 6 of 11
Not sure what else we can suggest.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 7 of 11
Hi @Wobbly,
If you have turned them off through your BT ID then it would point to an issue on our side. We'll need to get it looked into and sorted for you. Click on my user name and then click on contact the mods. You won't be able to see this using the mobile view so please switch to the full site view once you have clicked on my user name.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Wobbly
Message 8 of 11
Hi Daniel.
What do i do from here?
Message 9 of 11
@Wobbly wrote:
Hi Daniel.
Fill in the "contact the mods" form
Wobbly
Message 10 of 11
Can i get some help with this please
