Will5on
Message 1 of 6
Refreshing SIM data
For some time now I have noticed a message appearing on my phone screen : refreshing SIM data.
This is very annoying and happen many times a day. I have Galaxy Note 10. Is it sim card broken or so?
How to fix it?
5 REPLIES 5
Les-Gibson
Message 2 of 6
Re: Refreshing SIM data
You're not alone https://thedroidguy.com/note10-data-problems-after-android-10-update-1116043
♪♪I don't work for BT, I offer my time and help for free. If you'd like to leave a kudo, you may do so by clicking the rating button below.♪♪ 😄
Will5on
Message 3 of 6
I have android 11 already.
Message 4 of 6
I’m waiting for Android 11 on Samsung A series.
There are various suggestions on Android forums.
Did the problem start after the update?
Will5on
Message 5 of 6
I think I had this problem when I was on beta 11 too.
Message 6 of 6
Have you  checked your network connection settings?
You might try resetting the network connection and temporarily lowering from LTE/4G, down to 3G....then wait!...
This approach used to work for older mobiles for general connection problems when the signal was weak.
