Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
For some time now I have noticed a message appearing on my phone screen : refreshing SIM data.
This is very annoying and happen many times a day. I have Galaxy Note 10. Is it sim card broken or so?
How to fix it?
You're not alone https://thedroidguy.com/note10-data-problems-after-android-10-update-1116043
I have android 11 already.
I’m waiting for Android 11 on Samsung A series.
There are various suggestions on Android forums.
Did the problem start after the update?
I think I had this problem when I was on beta 11 too.
Have you checked your network connection settings?
You might try resetting the network connection and temporarily lowering from LTE/4G, down to 3G....then wait!...
This approach used to work for older mobiles for general connection problems when the signal was weak.
