RayVon
Message 1 of 2
Remove voicemail while roaming
How do you remove voicemail while roaming? I am in Cyprus at the moment and any incoming call goes straight to voicemail no rings at all
Spoke to BT guy who did not know how to do it apart from the usual check your settings switch off/on
The same is happening on wife’s phone as well, we are waiting for important family call so is there anything that can be done to remove it please
1 REPLY 1
Dean007
Recognised Expert
Message 2 of 2
Re: Remove voicemail while roaming
Hi @RayVon
Have you logged into your account at BT.com and made sure your spending cap for each number is above £0 as you often have to pay the incoming call charge..
