Dogandbone
Message 1 of 7
Replacement SIM CARD for new phone
Wife decided it was time for a new phone , so she  broke the bank and purchased an iPhone 11, went onto Mybt and ordered her a replacement sim stating it was for a new phone.
Well it’s been over a week and numerous very long phone calls to say no SIM card has arrived. Two separate  V ordershave been opened both stating orders for replacement SIM card complete.
Two emails to advise us to register the SIM card , YES you can guess we have not received any SIM cards at all
Over a week and still no sign of theses elusive SIM cards,
6 REPLIES 6
JohnC2
Moderator
Moderator
Message 2 of 7
Re: Replacement SIM CARD for new phone
Hi @Dogandbone  sorry that you have not received your Sim card yet.
Has the Sim card turned up yet?
If not when was the second Sim card ordered?
cheers
John
Dogandbone
Message 3 of 7
Still no SIM cards delivered.
1st order   01/08/ 2020
2nd order 06/08/2020
DavidM
Moderator
Moderator
Message 4 of 7
Hi @Dogandbone,
Thanks for confirming that. We'll need to take a closer look at this for you so I've sent you a private message so you can get in touch.
Cheers
David
Dogandbone
Message 5 of 7
Well the Farce continues, contacted bt mobile to advise that the second replacement SIM card did not arrive.
Well as before ,   “ We are sorry about that, we will send out another “ . So this will be SIM card number three
If this matter does not get resolved soon will be going back to O2 who I’m sorry to say should never have left in the first place
Dogandbone
Message 6 of 7
Well things have drastically deteriorated now, not only have we not received a replacement SIM card for my Wife’s new phone, BT in their wisdom have now disabled the sim in her old phone.
Have been On to  BT Mobile faults and they say there is nothing they can do but to wait for a new sim to arrive.
What a Circus act this is turning into.
Dogandbone
Message 7 of 7
All resolved at last , new sim card arrived I contacted bt mobile as instructed and after checking the SIM card number it was activated  almost immediately.
Compensation  was offered and was accepted. Wife now enjoying using her new iPhone .
