Message 1 of 7
Replacing mobile phone / from nano sim to eSIM
Hello,
I have BT Mobile 1GB 4G plan with my BT Fibre 1 Broadband package.
I'm using an old iPhone SE (BT nano-SIM card) very rarely,
but for compatibility reasons I need to replace it with a new one (SE 2nd edition)
which doesn't use any SIM cards (eSIM). What do I have to do now? I would like to continue using my old phone number on the new one.
Are there any settings to change on the BT website too?
Thank you.
6 REPLIES 6
Message 2 of 7
Re: Replacing mobile phone / from nano sim to eSIM
BT don't offer eSims but are you sure it doesn't use normal SIM's? A simple google search seems to advise it takes a nano SIM too
Message 3 of 7
My wife has an iPhone SE2, it definitely takes a Nano Sim. All you will have to do is swap the sim from one to the other.
Message 4 of 7
Thank you, you're right, I thought eSIM had replaced nano SIM. So no problem!
Message 5 of 7
Thank you.
Are you sure that there is nothing to change on my BT page?
I think I remember that I had to set up the phone model or some other info...?
But maybe not...
Message 6 of 7
I have swapped BT sims into several iPhones and have not had to do anything it all updates automatically.
Message 7 of 7
Great! Thanks.
