kdcoops
Message 1 of 11
Reward card missing
Anyone have any idea how to get the reward card actually sent out? I've been told 3 times now it'll be here in 30 days and it never arrives! I've phoned, emailed and used online chat with the same result " very sorry it'll be with you in 30 days" (no reply off email).
Feel a bit robbed as only picked BT as it £80 reward made it cheaper but now it's working out worse. I'm sure if I didn't pay for 3 months I'd hear off BT .
10 REPLIES 10
Dean007
Recognised Expert
Message 2 of 11
Re: Reward card missing
Hi @kdcoops
Sorry to hear it’s taking so long providing you meet the terms and waited 30 days before claiming it should be straight forward. But it’s managed by a third party.
Lets see if we can get a moderator to help you...
Moderator
Moderator
Message 3 of 11
Hi @kdcoops
Welcome to the community and thanks for your post!
I'm sorry for the time it's taking for you to receive the reward card that was included in the package you signed up to.  I appreciate the amout of your time you have spent chasing this.
Please send me over your details and I will check what's causing the hold up.  Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
kdcoops
Message 4 of 11
Sent you a message but no reply?
Moderator
Moderator
Message 5 of 11
@kdcoops I can't see anything in our email queue for you. Did you use the private message link? If so this is not how to contact us, instead can you fill in the click here to contact the mods link that @RobbieMac mentioned. You'll see the link if you click my username.
Community ModeratorNeilO
Kudos”Kudos”
Moderator
Moderator
Message 6 of 11
 @kdcoops I've picked up your email and have raised a case the the rewards card team to find out what's happening with this, as soon as I have an update I'll get back in touch with you.
Kudos”Kudos”
kdcoops
Message 7 of 11
Thanks for looking in to it for me.
Looking forward to getting it 😁
Moderator
Moderator
Message 8 of 11
@kdcoops The rewards card team have got back to me and advised that there is a delay with the card supplier at the moment but it's definitely on it's way to you and should be delivered in the next 10 working days.
I'm really sorry about the delay and I will follow up with you in a couple of weeks to make sure it arrives, but if you get it in the meantime can you post back to let me know?
Kudos”Kudos”
Moderator
Moderator
Message 9 of 11
@kdcoops I called there but missed you, I wanted to follow up to check that you've received the reward card? If you could post back here and let me know it would be greatly appreciated Smiley Happy
Kudos”Kudos”
kdcoops
Message 10 of 11
Hi that's for checking up, the card arrived the other day. Thanks for sorting this out for me.
