d_martin
Message 1 of 2
SIM PIN Locking
Hi,
I have just received a replacement SIM from BT, I would like to set up PIN locking on this new SIM, but there is no information about the current PIN on the replacement SIM. Is it the same as the PIN it is replacing on the old SIM, or is there a default PIN that I should use for the new one.
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: SIM PIN Locking
