Hdg
Newbie
Message 1 of 5
SIM activation
How long does it take ?
4 REPLIES 4
Dean007
Recognised Expert
Message 2 of 5
Re: SIM activation
Hi @Hdg
It can take upto midnight on the activation date. Keep turning the phone on and off... you should also get a notification when the service is ready
Hdg
Newbie
Message 3 of 5
Re: SIM activation
Ok thanks.  Is it normal to see a sim not provisioned message on the general settings on iPhone while I am waiting ?
Hdg
Newbie
Message 4 of 5
Re: SIM activation
Thanks switched off and on ( the normal IT solution...] and has worked.  Many thanks. Temperature back to normal !!!
Dean007
Recognised Expert
Message 5 of 5
Re: SIM activation
Hi @Hdg
Sometimes the simple things work, with iPhone 5S and above you can activate wifi calling and have access to 4G calling too...
BT Wi-Fi calling
