Sniborce
Newbie
Message 1 of 6
SIM card question
Can I obtain a duplicate SIM card for use on tablet in addition to phone?
5 REPLIES 5
Message 2 of 6
Re: SIM card question
It would have to be a new SIM and new number, on a separate contract.
If you are only using the tablet for mobile broadband, you  may be better looking for a mobile broadband provider. BT no longer provide just a mobile broadband only contract.
There are a number of PAYG mobile broadband providers, which may suit your usage better.
clever_trevor
Message 3 of 6
Have you tried the SIM in the tablet - works fine for me - I checked with BT & they said is fine also.....
Recognised Expert Dean007
Recognised Expert
Message 4 of 6
hi @Sniborce
As @Keith_Beddoe said normally it would require an additonal sim. BT do not offer any data only packs, but the other option is to use tethering if your handset supports it. Tethering along side the new plus packages offering double data works a treat (subject to fair use)
orozz
Message 5 of 6
Is BT about to launch data only tariffs? There are a lot of data only packages now appearing in the change plan area of My BT
Recognised Expert
Message 6 of 6
Hi @orozz
That’s a very good spot, seems they are upto something.
I would still look at teathering and/or upgrading to plus, over an additional contract. Or as mentioned before maybe something like a giffgaff data bag.
