Message 1 of 4
SMS limit
Hi I'm on a bundle that gives me unlimited SMS but is it really unlimited. Some providers have a limit a day week or month. EE was 5000 a month on an unlimited SMS plan does bt do something of the same?
3 REPLIES 3
Message 2 of 4
Re: SMS limit
It's unlimited. Download the MyBT app and you can monitor your usage if you wish to
Message 3 of 4
Re: SMS limit
I can't speak for EE but as I said earlier, if you download the MYBT app you will be able to see for yourself if your allowance decreases. I've been with BT for a number of years and I've never had such a problem
Anonymous
Not applicable
Message 4 of 4
Re: SMS limit
Isn’t there something about not using it for commercial purposes in the T&C for you’re a B2C customer?
I would expect that if someone is regularly hitting 10k SMS a month then they might start to look into it.
