Newbie
Message 1 of 2
Samsung Galaxy S7
My S7 keeps rebooting itself.  I read online the best way to cure this was to take back to factory settings.  I have done this but it now keeps rebooting whilst I build the phone.
I think the battery is knackered I have had the phone less than a year what should i do?
1 REPLY 1
Distinguished Expert
Message 2 of 2
Re: Samsung Galaxy S7
Change the battery if it's running hot and you are sure that the phone isn't damaged!
I hope that you haven't dropped the phone accidentally.
Suggest that you check the battery and phone warranty and argue later.
