Message 1 of 1
Samsung Galaxy S9 Earphone Problem
I have a Galaxy S9 on contract with BT. Whenever I use the earphones, after I take them out, I cannot get any sound on the phone to work. It is as though it thinks the earphones are still plugged in. The only way to get the sound back is to do a restart. I am a bit fed up doing this and looking to see if anyone has a solution.
I googled the problem and it brought up same issues with older versions of the Galaxy. The only resolution I could find was someone said to blow air hard into where the jack goes as this should clear it. Sadly it doesn't for me.
It is really annoying and if anyone has a suggestion for a fix I would be very grateful.
