Teekaygandoo
Message 1 of 8
Samsung s10 5g
If I buy this device from Samsung locked to ee will it work with bt sim on 4g network. Bt says ee handsets need unlocking
7 REPLIES 7
Teekaygandoo
Message 2 of 8
Re: Samsung s10 5g
ANYONE??
Message 3 of 8
Re: Samsung s10 5g
Teekaygandoo
Message 4 of 8
Re: Samsung s10 5g
That's just a standard script. Ee advise bt sims will work but why do bt state and advertise that they need unlocking.
Message 5 of 8
Re: Samsung s10 5g
If you go to EE forum there are mixed reports some people say it worked and others say BT sim did not work. Even EE employees on their forum first said ok then another post said it would not. So who can you believe
Message 6 of 8
Re: Samsung s10 5g
If you are not happy with the answer that BT, the company that you moving to has given you then all you can do is try it and see. If it doesn't work you will just need to get the phone unlocked!
Teekaygandoo
Message 7 of 8
Re: Samsung s10 5g
I haven't stated that I'm moving to bt. Im already with bt. My intended new handset is locked too ee
Bezman
Message 8 of 8
Re: Samsung s10 5g
I personally have had no problems putting a BT sim into a EE locked phone. My last phone was a Samsung Note 9 which worked a treat including 4g calling and wifi calling.
