Message 1 of 4
Scam messages on Samsung A71 mobile
I posted the following problem on the 9 July 2022 and received a response at the time which seemed to have solved the matter – however, the same message is again coming up, sometimes 2 or 3 times a day.  I have McAfee security installed which seems to keep the phone secure. But the continual appearance of this message is disconcerting and very annoying.
I have gone through Chrome to delete the browsing record many times, I have also got McAfee to scan the phone and see if this would delete the message.  All without success.
Suggestions please.
Every time I open my phone the following comes up...
This site can't provide a secure connection
Kirutotukan.com
uses an unsupported protocol.
Can anyone help me to get rid of this nuisance?
3 REPLIES 3
Message 2 of 4
Re: Scam messages on Samsung A71 mobile
Message 3 of 4
NigelB72
Many thanks - lots of ways to try to solve the issue. I shall go through them as suggested.
Message 4 of 4
It appears to be a rogue cookie that's causing the issue. Check to ensure that your Android OS is fully up to date as they release regular updates. It might be that Samsung aren't pushing the latest ones through as they'd like you to upgrade.
The rogue cookies pop up a lot on sites heavy with advertising...
