Deryman
Message 1 of 2
Signal Boost trial "just ended"
So, just called BT and was told Signal Boost was just a trial which "ended yesterday" (14/9/17) with no known plans to reinstate.  So what on earth is going on?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Signal Boost trial "just ended"
Hi @Deryman and thanks for posting.
The information you've been given is correct. This was a limited trial and has now ended.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
