Cloudy
Message 81 of 183
Re: Signal booster
I received my new BT Sim today.  Signal indoors poor.  BT Mobile technical team has launced a new Signal Assist Box about two weeks ago.  Eligibility determined by some tests (no idea what these do).  New box on its way to us.  We live in old building with three foot walls.  We shall see if this works.
Ring 0800 800 150 and ask for BT Mobile Technical Team.  Try again if you need Signal Assist is what I recommend.
EdSutton
Message 82 of 183
Re: Signal booster
Yes. As others, I rang up and they ran long tests. Call took 35 min but I've been promised a box in 3-5 days.
Moonboots
Message 83 of 183
Re: Signal booster
Hi,
When i rang up the guy said he would send a signal box out but have not heard anything since.
Did anyone get emails etc to say it was coming as the guy said i may get info sent to me.
Just want to make sure that its being sent out
Cheers
GrandadClive
Message 84 of 183
Re: Signal booster
Hi Moonboots
Come to think of it no didn't receive anything except the box which just plugs in and works like magic.
Spoke on Monday box arrived Friday.
Grandad Clive
Moonboots
Message 85 of 183
Re: Signal booster
Thanks for the info Grandad Clive,
I hope it is on its way then, fingers crossed
Cloudy
Message 86 of 183
Re: Signal booster
I was promised signal booster and told it would arrive in 3-5 days but no email confirmation.  We shall see.
Dogandbone
Message 87 of 183
Re: Signal booster
Received the booster today, I had a text from DPD to confirm approx delivery time ,  have set it up as per instructions, now just waiting for the green light to stop flashing could be up to 24 hrs to activate, I assume I do not have to phone BT to activate  ?
GrandadClive
Message 88 of 183
Re: Signal booster
Mine did that so I turned it off and on again and it went steady green
GrandadClive
Message 89 of 183
Re: Signal booster
Didnt have to call BT
Dogandbone
Message 90 of 183
Re: Signal booster
Well the assist signal booster has been switched on for 26 hrs now , still flashing green , have been in contact with technical support have carried out soft and hard resets  without any success, so now have mobile phone x2 and assist signal booster that do not work, the only saving grace was the booster came FOC .Smiley Mad
Spoiler
Spoiler
Smiley Mad
