Message 1 of 2
Sim cards
Hi Guys,
Got a sim only package that I've had for a few years.  Just ordered a new phone off Amazon.  Question is, do I need to tap BT up for a replacement sim or can I just move the old one across to the new phone, (assuming it fits, of course)?
1 REPLY 1
Message 2 of 2
Re: Sim cards
If it’s the same size SIM and the phone you bought off Amazon is unlocked to work with any network, it should work fine.
If you need a different sized SIM, then BT should be able to send you one on request.
