Message 1 of 5
Sim query
I’ve just switched my mobile contract to BT. Everything went more or less smoothly but I’ve found I can’t use the BT Mobile app or either of the two “4g apps” with my 3 year old phone.
However my wife has magnaminously offered to let me have her phone and she will get a new one!
My new phone will do all that I’ve mentione above but takes a nano sim so I will have to cut down my present sim. If I make a pig’s ear of the procedure and ruin it will I be able to get a new sim from BT  supplied with my current number?
Thanks.
4 REPLIES 4
Message 2 of 5
Re: Sim query
Thanks.
Hi @Vetch. The chances are the Nano sized sim will simply snap out of your Micro? sized sim. There should be no need to “cut down” your BT sim.
Message 3 of 5
Re: Sim query
Thanks,
Yes that's what I did when I switched to BT. I had to use their supplied sim pressed out of it to initiate the change over then swapped their number with mine. I didn't notice if you could do that again to get to the nano.
I'll have to have another, closer look to see if I can do what you say.
Thanks again
Message 4 of 5
Re: Sim query
Hi @Vetch. To quote the following page
BT Mobile and most other operators send out SIMs in a 3-in-1 card that lets you pop out the SIM size that fits your phone.
http://home.bt.com/tech-gadgets/phones-tablets/which-type-of-sim-card-is-right-for-your-phone-113639...
Message 5 of 5
Re: Sim query
I'm very sorry I didn't acknowledge your post, you were quite correct, the nano sim just popped out like you said.
When people go to the trouble to help the least I could do is reply.
Thank you for your help
