Message 1 of 2
Snapchat and Messenger not working on data
Having the same issue. How do I remove the parental lock?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Snapchat and Messenger not working on data
Hi @Kmnemecheck2012,
I've moved your post onto your own thread. If you take a look at - Parental Controls you'll find the instruction on how to turn off parental controls.
PaddyB
