mzm70
Message 1 of 3
Swapping data allowances between SIMs on the same account
Hopefully an easy one,
I have a total of 5 SIMs on my account, 2 Family SIMs with 40GB data and 3 with unlimited of data, my daughter with unlimited data doesn't need that much, can I (in the Family SIM) swap allowance?
I seem to remember the Family SIMs must have the same package so can she transfer in and I transfer out?
Thanks for any assistance.
Michael
2 REPLIES 2
DavidM
Moderator
Moderator
Message 2 of 3
Re: Swapping data allowances between SIMs on the same account
Hi @mzm70 and thanks for posting.
Take a look at What's a Family SIM?  'One single plan - each SIM comes with its own allowance, equal to yours. And because it's all on one plan and one bill, it's easy to manage'. If you need to swap your best bet would bee to give the mobile guys a call on 0800 800 150.
Cheers
David
mzm70
Message 3 of 3
Thanks David,
I'll give them a call
Michael
