Newbie
Message 1 of 5
Switched to BT Mobile with my 3 No. - Apple Phone still showing the temporary BT no. as Default No.
I recently Switched to BT Mobile with my 3 Number - in the main settings, my Apple Phone is still showing the temporary BT number as the Default Number. Tried every help under the sun as available on the Apple Support but could not sort it out.
That is impacting my Facetime and imessages to as that is set to the temporary BT number instead.
Any help/advice would be much appreciated.
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Switched to BT Mobile with my 3 No. - Apple Phone still showing the temporary BT no. as Defau...
Hi @atifiqbal, my understanding is you need to update the number in your iPhones settings. I found this helpful guide on the apple website that expains how you can do this.
Newbie
Message 3 of 5
Re: Switched to BT Mobile with my 3 No. - Apple Phone still showing the temporary BT no. as Default
Hi
Newbie
Message 4 of 5
Hi
Message 5 of 5
Hi @Ncfc253
Do you require any help ?
