Galad
Message 1 of 4
Texting to Australia
Hi
I've just received my new mobile from BT on a pay monthly contract. I tried to send a text to my daughter in Australia using the correct country code but it failed to send. Is there something in settings that I need to adjust? Thanks.
3 REPLIES 3
Message 2 of 4
Re: Texting to Australia
Check your call setting to make sure Intenational calling is enabled, and your spend limit is not set to zero.
Message 3 of 4
You and your daughter should install the "Whatsapp" app and you will be able to call, text and video call for free over the Internet.
Distinguished Guru
Distinguished Guru
Message 4 of 4
Just to clarify, is your daughter resident in Australia with a local phone or is she visitng with a UK-registered phone? If the latter, the Aussie country code is not appropriate.
