Bmcleod
Newbie
Message 1 of 3
Texting with BT WiFi calling
I recently changed from O2 to BT as O2s Wi-fi calling does not support texting. As we get very poor/no mobile signal at home this was important to me.
however it is still not reliable with BT and I find I cannot send texts still. I have turned off and back on again but this didn’t help.
please can anyone help me?
Many thanks
2 REPLIES 2
foddersin
Message 2 of 3
Re: Texting with BT WiFi calling
For the past few week myself and my wife have a difficulty sending text message and having them fail. This is with WiFi calling both on and off.
Since BT use the EE network and their implementation of it I believe that text will also be carried using the IMS for it.
Try using only mobile connection and see if that helps.
Andy005
Message 3 of 3
Hi @Bmcleod and @foddersin,
I would recommend considering one of these:
https://www.shop.bt.com/products/bt-signal-assist-40009142-DJHZ.html
It generates a local 3G signal from your broadband with the main purpose of providing a signal for calling, but of course it also allows you to send and receive texts. I've had mine for over a year and never had a dropped or missed call, I find it to be better than wifi calling.
