Bawbee
Message 1 of 3
Transferred Mobile Number
When sending texts the recipients do not see my saved number. I have recently transferred to BT and kept my old number. Anyone have a solution?
2 REPLIES 2
ctrlz
Message 2 of 3
Re: Transferred Mobile Number
If you're using an iPhone you might need to check that your old number is saved in your settings, as this affects iMessages/facetime:
  1. Go to Settings > Phone > My Number
  2. Replace the temporary number that's there with your own number - use +44 instead of the first 0
  3. Then tap Save
Bawbee
Message 3 of 3
Thank you all for your responses.
I finally hit through to a BT Technician and we tried all the usual steps without success. He finally advised that I should backup everything and perform a factory reset. Problem Solved.
