Georgemcg
Message 1 of 2
Twitter not loading on Bt mobile
Hi I recently changed over to Bt mobile and since I’ve changed I no longer get tweets loading? I’m on iPhone 5se and this was not an issue with my last provider. Can anyone help? Is it a setting issue ? Or what ?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: Twitter not loading on Bt mobile
Hi @Georgemcg  welcome to the forum and thanks for posting? Sorry that you can't get Twitter on your BT Mobile.
If you are still experiencing this issue try turning off your phone and back on again. Also check if there are any updates for Twitter on the App. If it is still not working it may be best to uninstall and install the App again.
Cheers
John
