new
Message 1 of 6
UK text charges
I have three family sims, I notice that 2 of these are showing charges for UK texts, are these not included? The charges are not large, one is 40p and one 25p
5 REPLIES 5
StewM
Distinguished Guru
Message 2 of 6
Re: UK text charges
Hi @new  have a look at the breakdown of mobile charges in MyBT.
MMS are chargeable at 40p each while SMS are included. Also, the 25p could be a text to a premium number?
Stew
Carlusha
Recognised Expert
Message 3 of 6
Re: UK text charges
Fire up MyBT, click on "Your usage" and you can see exactly which calls each of the SIMs have made and when. You will be able to check whether they are included in the "allowed" (free) texts.
Apologies, my post crossed that of @StewM
new
Message 4 of 6
Re: UK text charges
Thanks, I'll need to tell my family about texts, I think when we were with Three they were included.
StewM
Distinguished Guru
Message 5 of 6
Re: UK text charges
Normal texts will be Included.
Stew
pottyperson
Distinguished Guru
Distinguished Guru
Message 6 of 6
Re: UK text charges
@new  You also need to make sure that the phones are not set to send group texts as MMS.
