Solved! Go to Solution.
@noopjay wrote:
What is this? What is a bolt on?
I’ve followed the process on the BT website. Why would I suddenly need to buy a bolt on?
Is this what you’re directing me to??!
I thought it was the same thing, just called something different. If you read that thread, is that what you are trying to do?
I have read the thread as requested and it doesn’t help me.
I have already requested and paid for my add-ons. I have received the text confirming that the data has been added.
HOWEVER, in terms of my mobile app and my online account, there is NO evidence of this being added.
The thread suggests calling up BT to get it manually added. I have already phoned BT twice and they say it’s added to my account, yet I cannot see it anywhere.
Anyone reading this knows 100% that as soon as I touch down in USA my phone will not have the data attached as per requested and I will get charged all sorts to which BT will just say “sorry, should have stuck to Wi-fi” whilst draining my bank account.
HELP!!!
Hi @noopjay
Thanks for your post. Sorry to see you're having these problems. I have sent you a private message with advice on how you can send us your details and we'll get it looked into.
Cheers,
Robbie
Community Moderator | RobbieMac | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the star next to a reply to say thanks | Help guide to using the community? Click below |
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You |
Hello @RobbieMac - would you be able to provide any update?
Its likely to be a few days, as the team deal with each request in strict order.
Clearly BT will therefore cover the costs that I will incur from having to use my own normal data?
Hi @noopjay,
I am sorry that we haven't been able to pick up your case yet. There are a few people ahead of you at present. As soon as we've helped them we will be in touch with you.
Thank you
DanielS
Community Moderator | DannyS | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the thumbs up next to a reply to say thanks | Help guide to using the community? Click below |
