Message 1 of 4
Unable to make phone calls from mobile
I recently switched to BT mobile and have an unlimited calls/texts and 15GB data each month.
I am unable to make phone calls from mobile to fixed and/or mobile numbers, it says I've reached my limit.
Also I am not able to send SMS (not send error, try again) I've checked settings and it all seems ok.
Hope this all makes sense. Can you please help?
3 REPLIES 3
Message 2 of 4
Re: Unable to make phone calls from mobile
Hi @tjhov Thanks for your post, I'm sorry to see you're having problems with your BT mobile. Do you have a spend cap set up on your BT Mobile account? If you click on the link I've posted it will show you how you can check this.
Neil
Message 3 of 4
Hi,
Thanks for your reply. I've checked my settings via the link you sent me.
I have no spending cap set and have unlimited calls and texts, nothing barred or anything.
This is really strange. Do I need a new SIM perhaps?
TJ
Message 4 of 4
Can you receive incoming calls?
When you say you have no spending do you mean cap set to zero or unlimited spend?  If set to zero try setting to a positive limit and see if that helps
