rockmc
Message 1 of 2
Unable to receive calls in Europe (found workaround)
Hi
I found that I wasn't able to receive calls when in Europe.  I could make them and could send/receive texts but all incoming calls went straight to voicemail.
I tracked down the problem to the fact that I have my monthly spending cap set to zero.  Although incoming calls in Europe are free, BT appears to check the cap first.  I've now set the cap to £2.50 and can receive calls - even though no charge is applied.
Ideally BT should fix this bug so I can leave my spending cap at zero and still use my phone in Europe.
1 REPLY 1
clever_trevor
Message 2 of 2
Re: Unable to receive calls in Europe (found workaround)
Thanks for this find - hope BT fix this quickly....
