g-lou11
Message 21 of 27
Re: Unable to send /receive WhatsApp images on cellular network
Hi @NeilO. Yes, that was one of the first things I tried. I have also spoken to WhatsApp who said this:
“If you are experiencing issues with mobile data connection but have no issues accessing WhatsApp via Wi-Fi connection, then the issue is likely caused by your mobile data service provider or mobile data setting. Likewise, if you are experiencing issues only on Wi-Fi connection but not on mobile data connection, then the issue is likely caused by your network's security setting or your Internet service provider.”
“Since WhatsApp and its features only work with one of your connections at a time (either Wi-Fi or mobile data), and you're experiencing this problem on one of these connections, then please contact your service provider or network admin for more information.“
Moderator
Moderator
Message 22 of 27
@g-lou11 I'm sorry that hasn't worked. I've asked my colleague in the Mobile team if there is anything further that we can do to help.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 23 of 27
Kudos”
Subodhk58
Message 24 of 27
@NeilO Some additional information that might help is that when I use a diffrent Company's SIM (i.e. O2) on the same phone then  my photos and videos download without any problem. I also recently went to Marrakech where I used a local company's sim card and again there were no problems in dowloading photos etc. The issue seems to be only with BT Sim card.
Subodhk58
Message 25 of 27
Hello @g-lou11
Good news. I have found out that this issues occurs due to your "Parental Control" setting being too high. If you amend the setting to "Light" then everything works fine.
I hope this helps.
Message 26 of 27
Try to reset the factory setting of the phone. Sometimes the network setting is saved to default 3G. It happens that the user change the settings to 4G but it remains 3G only. So by restoring phone settings it might change to 4G.
g-lou11
Message 27 of 27
Hello @Subodhk58
Thank you so much for your suggestion which has resolved my problem. A simple fix in the end!
Thank you!
