Longshanks
Expert
Message 1 of 5
Unable to use my BT app to monItor BT mobile data usage
Hi
Apols if this been asked b4. The BT WiFi app went a while back. When I now log into My BT, mobile doesn’t appear when you select usage. When you select products, mobile, you eventually see option “already got mobile with us? Log into your account”. When you try that the app just crashes.
Any advice would be much appreciated.
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
Re: Unable to use my BT app to monItor BT mobile data usage
Hi @Longshanks, is your BT Mobile service billed on the same account as your landline?
Longshanks
Expert
Message 3 of 5
Hi Neil
Hope you’re ok. That’s a very good question. No, mobile not on main bill.  Only transferred from EE to BT about a years go. Set up new DD out of my bank account. (Broadband and BT Sport comes out of our joint account)
There was lots of reassurance when the BT WiFi app went that you could monitor usage via MyBT. I guess I’d have to somehow log out of MY BT and log in with email used when opening BT mobile contract? Not sure if that’s right?
Bit confused and confounded.
Thanks again.
Longshanks
Expert
Message 4 of 5
Just logged in with email and password created when I started mobile SIM only contract. Everything fine now.
NeilO
Moderator
Moderator
Message 5 of 5
Hi @Longshanks, I'm good thanks, that's great I'm glad you got it sorted.
