Sarahc75
Message 1 of 4
Upgrade issue
I am trying to upgrade my mobile handset do they carry out another credit check when your doing an upgrade even though Iv got a handset with them for two years as I can’t seem to upgrade
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Upgrade issue
Hi @Sarahc75. Thanks for posting, in answer to your question an external credit check using Equifax isn't carried out. However, we do a review of your BT account payments before an upgrade order is accepted.
Sarahc75
Message 3 of 4
Re: Upgrade issue
Ahh Thankyou Iv just finished a payment plan after arrears how long do they monitor this for do you know thanks
NeilO
Moderator
Moderator
Message 4 of 4
Re: Upgrade issue
Hi @Sarahc75, no problem, the check is based on your BT payment history over the previous 12 months.
