Message 1 of 2
Upgrading phone but staying with same carrier (BT Mobile) - Do I need a PAC code ?
I've decided to retire my old mobile phone and replace it with something newer and smarter. I don't want to switch network carrier because I have been perfectly happy with the service provided by BT Mobile, and I also want to retain my old phone number
I will be buying the new phone outright so will not need to enter a new monthly contract to pay for the phone. Currently my phone is on an open ended contract with BT which provides all the data/calls/texts that I need.
Is it simply a case of taking the Sim card from the old phone putting it into the new phone ?
There's plenty of information available about porting a phone number to a different carrier using a PAC code but nothing that provides much help for my situation.
Thanks for taking the time to read this posting.
1 REPLY 1
Message 2 of 2
Re: Upgrading phone but staying with same carrier (BT Mobile) - Do I need a PAC code ?
@jimboknowsnowt
Quick answer is Yes it's that simple.
The only complication is that the sim card might need adjusting to fit the new phone but that should be a simple process.
