Message 1 of 3
Using Mobile in Tenerife (Canary Islands)
My child is going on  holiday to Tenerife for 1 week and I want to make sure that their mobile is set up cost effectively,
Is there anything that they should do prior to going away.
They have 20GB data
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: Using Mobile in Tenerife (Canary Islands)
Log in to MyBT and make sure that international roaming is enabled on the account, set an extra spend limit of £20 and also check the roaming settings on the phone.
Message 3 of 3
thanks
