ACBHammersmith
Message 1 of 3
Using MyBT app instead of BT Mobile app to get mobile data usage
I have several mobiles on my account. Some of them are used by my children. Using the old BT Mobile app installed on each phone they could see how much data they had left only on the phone they were using. Now it seems the BT Mobile app has been discontinued and I have to use the MyBT app instead. This requires a login to my BT account. This means my children will have access to all features of that account including parental controls. How can I restrict it so they can ONLY see their own data usage on the phones they are using - the functionality the BT Mobile app had ?
2 REPLIES 2
imjolly
Message 2 of 3
Re: Using MyBT app instead of BT Mobile app to get mobile data usage
this was raised already and using the forum search
https://community.bt.com/t5/BT-Mobile/BT-Mobile-app/m-p/2061522
ACBHammersmith
Message 3 of 3
Thanks - that was exactly the information I wanted and it worked fine.
