deejay
Message 1 of 6
Virus protect installation problems on a mobile
Morning all
Samsung A20e Android 9.0
Morning all
New mobile. Downloaded the BT Virus Protect app to the mobile.
Open the app and there is a procedure to choose a few options.
A link to get an activation code appears.
Log in to my  BT OK.
Click link - blank screen.
Down powered and repeated - same result.
Any suggestions please?
Cheers
Dave
5 REPLIES 5
deejay
Message 2 of 6
Re: Virus protect installation problems on a mobile
Bump.
DavidM
Moderator
Moderator
Message 3 of 6
Hi @deejay and thanks for posting.
I'm sorry you're having problems installing the virus protect app. It sounds like there's a problem so we'll need to take a closer look at this for you. I'll drop you a message so you can get in touch.
Cheers
David
deejay
Message 4 of 6
Morning David
I found a solution to this after I bumped the thread.
I found ...
https://www.bt.com/help/security/bt-virus-protect-app#getit
Under 'Getting started' none of the links worked. I had this before. That might be worth looking at.
However, if you scroll down to
How can I get the BT Virus Protect app for my Android mobile or tablet? there are three options.
Option 1 didn't work.
Option 2 .  I went straight to the Google Play store App. Basically I followed the prompts, downloaded the app, logged in to my BT when prompted, got the activation code and followed the rest of the instructions.
Cheers
Dave
DavidM
Moderator
Moderator
Message 5 of 6
Morning @deejay,
Thanks for getting back to me. I'm really glad you found the cure to the problem. Thanks for posting that. I'm sure it will help other users. Kudos to you.
Cheers
David
deejay
Message 6 of 6
You're welcome
Cheers
Dave
