mtm1962
Newbie
Message 1 of 9
Voice Mail Notification
Is there a way to get notification that i have a voice mail. I have been through all the options on 1571 but cant find anything other than an option to receive an internet message if someone doesnt leave a voice message!
It used to be that i would get a call from 1571 saying i had voice messages but now i have to manually call 1571 every so often tos ee if i have anything. Not all missed callers leave a voice message so dont want to check 1571 after every missed call.
8 REPLIES 8
Message 2 of 9
Re: Voice Mail Notification
You should receive a text message for a missed call, and if the caller left a message.
mtm1962
Newbie
Message 3 of 9
No, I am not receiving any notification.
Message 4 of 9
The best thing to do is to contact the Mobile Chat Team
mtm1962
Newbie
Message 5 of 9
I can see if i have a missed call, but i dont get any notification if a voice message has been left. It's difficult to answer the phone at work and I dont want to check 1571 after every missed call. Anyone know if it's possible to get notification from 1571 when a voice mesage has been left, or is it a case of having to manually check ?
Message 6 of 9
Hi @mtm1962   You should get a text message, something is wrong. Best to contact the mobile team above.
Message 7 of 9
I am sure that on my BT Mobile, It says that I have a missed call, and the caller has left a message. Otherwise it just shows a missed call.
Message 8 of 9
I have just tried it as a test. I left a message and immediately got a text message “You have 1 new voicemail. To listen to your voicemail, call 1571”.
mtm1962
Newbie
Message 9 of 9
Called Chat Team. went through turning on and off voicemail (15710 and 15711), turned out that i had previously blocked 1571 so i wouldnt receive any text notification!  Cant remember doing that, must be old age setting in..  Thanks for your advice to call the Chat team!
