Message 1 of 2
What is the fix for when i can't text a french mobile number?
It just won't go.....
This is recurring
1 REPLY 1
Message 2 of 2
Re: What is the fix for when i can't text a french mobile number?
Check MYBT and that you have your mobile spend limit set to above zero
