Message 1 of 4
Why do I keep getting notifications to say that "no data is available"
Never have I so often had no data/ phone reception unavailable since I moved over to BT. Is this common? And then when it comes back on it H or E reception.
3 REPLIES 3
Message 2 of 4
Re: Why do I keep getting notifications to say that "no data is available"
Hi @Wigglyboston
What is the signal strength shown on the coverage checker?
https://www.bt.com/mobile/4g-coverage-checker/
Message 3 of 4
Usually it's between 4G and H+. The checked states 4G area.
Message 4 of 4
Is it the indoor or the outdoor data signal which is failing?
H+ is one step below 4G. E is very slow, but can you get E indoors?
Is it an Android phone?.....there are apps you can install, to show mast locations.
