ctrlz
Message 11 of 23
Re: WiFi calling stopped working after upgrade to Android 11
Could try disabling VoLTE/4g calling, and seeing if Wifi calling works then. I know some Android's prefer to use 4g calling over Wifi calling if both are enabled. Where i live i barely get any 4g so before i got an iPhone i had to have 4g calling disabled to get anywhere.
pddco
Message 12 of 23
Switching the phone to Airplane mode turns off the GSM/3G/4G radio bits so that’ll check whether WiFi Calling works or not.
s1ms
Message 13 of 23
This issue is related to BT. Got confirmation. Apparently I am not the only one with non-working WiFi calling.
Trust me, I've tried all the above things and more before I contacted BT.
MrBelter
Expert
Message 14 of 23
You probably know this already but dial *#*#4636#*#* to see if VoLTE and VoWiFi are provisioned on the SIM.
s1ms
Message 15 of 23
SIM is fine and everything is working if I put it in another phone. A different SIM is working on well my phone. What is not working is the BT SIM on my Note 20.
s1ms
Message 16 of 23
What an interesting sequence of events.
Decided to get a new phone. Got Samsung S21 Ultra 5G. Same problem. Wifi calling broken!!!
Samsung Korea got in touch with BT network Engineers with a solution and we've got if fixed!!! Permanent fix should be released with a new firmware upgrade.
Very good collaboration with the BT Engineer!
arjanvirdi
Message 17 of 23
I had the same issue with my Ultra 5G. Weird occurrence, I let the phone die, and after charging and turning it, it said new network features, and to restart. After that Wi-Fi Calling, and VoLTE appeared, and worked! Also, have you installed the software update?
s1ms
Message 18 of 23
my problem had nothing to do with that. There is an issue with the phone firmware that has been confirmed by Samsung Korea software team 😉 Trust me, I have tried everything. The good thing is we have found the issue and temporarily fixed it while we wait for the new software.
Ian73
Message 19 of 23
I have same issue as yourself. What is the way around this.
Cheers
s1ms
Message 20 of 23
You need to add a custom APN as per below instruction:
Settings - Connections - Mobile Networks - Access Point Names - Add -
APN: ims
APN type: ims (Delete "default" that was written at the beginning)
APN protocol: IPv6)
Click Save
